Stryker - FloControl
by Stryker
Stryker FloControl Inflow/Outflow Arthroscopy Pump
The FloControl pump controls both inflow and outflow as well as regulates shaver suction with a variable flow rate. No special cannulas are needed; however, Stryker “high flow” arthroscopic cannulas or the Stryker Inflow/Outflow cannulas are recommended.        Tube sets are ergonomic and intuitive to set up. The FloControl arthroscopy pump can also be used as an inflow only pump. This feature is ideal for shorter procedures or cost cutting measures within the OR.
-RFLAEL01
Mon Nov 10 2025
MANUAL SERVICE
Manual service
Thank you
[list]    [*] Programmable joint icons change the flow rate and pressure for ideal performance during knee, shoulder and small joint procedures    [*] Wash button quickly clears the joint of debris. Length of wash and pressure increase can vary depending upon surgeon preference    [*] Fluid conservation feature helps maximize OR efficiency and reduce cost    [*] LCD screen display provides easily identifiable digital readout of flow rate, preset and in joint pressure    [/list]
