Olympus - Visera Elite OTV-S190
by Olympus
The VISERA ELITE Video Processor OTV-S190 brings out the full new scope performance. The Multi-platform system enables existing scopes to be used as well. Stabilized colour reproduction and image noise reduction improving image quality to the next level.
1ReplySat Aug 26 2023 | DF is not connected E402 Connect DF - on monitor error message. Has anyone solved the "DF not connected E402 error code"? My customer is using an Olympus OEP-5 printer and is not using the internal image management system to capture pictures from the OTVS-190 with a flash stick. I can't find anything online. Equipment: Olympus OTVs-190 Reply |
0RepliesTue May 18 2021 | PM - frequency and procedure What is the PM frequency and procedureReply |
0RepliesTue Feb 16 2021 | Compatibility Is the OTV-S7H-1D-F08E camera compatible with this console? Thanks.Reply |
[list] [*] Ground- breaking resolving power for safe procedure - Equipped with the next generation HD imaging capability to provide the best possible quality for flexible and rigid endoscopes. Enables comprehensive observation of different organs and tissue. [*] Brighter, more powerful NBI - Narrow Band Imaging now delivers significantly increased brightness and contrast. The light source filter configuration has been optimized to increase the brightness of the NBI light by 1.2 times. This enables the surgeon even to operate under NBI visualization. [*] Outstanding, true-to-life image quality - With 3D noise reduction the image quality of all new scopes and camera heads will tremendously improved. [/list]
| Height | 85 mm |
| Length | 455 mm |
| Weight | 8.8 kg |
| Width | 370 mm |
