Olympus - OEV262H Color Monitor
by Olympus
The ideal synergy with OLYMPUS endoscopy systems, this high-end monitor meets a wide range of clinical needs. The clearest picture quality is guaranteed by the high brightness, contrast and gradation. While a range of display modes, image-size combinations and image enhancement functions make this a versatile choice.
1ReplyMon Mar 30 2026 | LCD doesn The LCD doesn't always turn on, the tally doesn't flash. |
[list] [*] High definition, brightness, contrast and gradation - This 26-inch, full-HD LCD panel has a 16:9 aspect ratio, high brightness, high contrast, and high gradation images for the clearest picture [*] Improved resolution of fine structures - The A.I.M.E. (Advanced Image Multiple Enhancer) function significantly improves the resolution of fine structures without additional noise on the image [*] Flexible compatibility - The monitor’s input/output terminals include 3G/HD/SD SDI (2×), DVI-I (2×), HD15, Y/C, and Composite for wide compatibility with other system components [/list]
