ConMed Linvatec - Advantage
by ConMed Linvatec
A full-function, electric powered system that uses multiple electric handpieces...
for a wide range of surgical applications including Arthroscopy, Large Bone Orthopedics, Small Bone Orthopedics, Orthopedic Trauma, Oral and Maxillofacial Surgery, Otolaryngology, Neurosurgery, and Spine Surgery. Because it is a complete, standardized and specialized all-in-one system, the Advantage System provides significant cost savings, simplified inventory management, and ease of use. Each of the system handpieces has been designed to meet the specific needs of each individual surgical specialty in which the handpiece is used.
  • Operates more than 24 different handpieces
  • Can operate two handpieces simultaneously
  • Easy to use
  • Simplifies O.R. setup and inventory management
  • Closed-loop software control provides constant power output under any load
  • Provides built-in irrigation pump for use in irrigating surgical site
  • Both hand or foot control of handpieces is available
  • Designed for use in Arthroscopy, Large Bone Orthopedics, Small Bone Orthopedics, Oral/Maxillofacial Surgery, Orthopedic Trauma, Otolaryngology, Neurosurgery, and Spine
  • Operating speeds and modes may be controlled from inside or outside the sterile field
