Euronda - E9 Med
by Euronda
Class B autoclave for dentists
The simple, effective and compact E9 Med is an autoclave that makes Class B sterilization truly accessible to everyone. The Process Controller and interactive display guide you through every procedure, for outstanding performance that is also boosted by the Steam Generator. The built-in thermal paper printer and the E-Memory system trace and store details of every operation for maximum safety.
-Rlmc
Mon May 30 2022
Passsword
Olá, fiz revisão completa ao autoclave E9 e precisava de password para repor valores, alguém poderá ajudar? ObrigadoReply
2
-Bilal Javed
Sat Feb 11 2017
Autoclave
Hi Guys, Please can you send me the service manual of Euronda E9 or help me in the problem that the autoclave failed to switch on? Kindly guide me through.Reply
[list]      [*] Hight Performance: Outstanding steam production is guaranteed with the Steam Generator      [*] Reliable: With an air-water separator as standard, for a longer working life      [*] Simple: Display with an interactive menu and a Precess Controller that guides you and tells you when maintenance work is required      [*] Traceability: Built-in thermal paper printer and E-Memory system, for traceable sterilization cycle data      [/list]
Chamber Volume18 L
Height445 mm
Length 450 mm
OrientationBenchtop
Weight41
Width610 mm
