GE HealthCare - CARESCAPE B450
For smart intra-hospital transport and bedside monitoringThe convenient CARESCAPE* Monitor B450 is robust and flexible enough to meet a patient’s changing acuity and care needs, and light enough to travel with the patient throughout your hospital. Just unplug from the bedside and go; the wireless capability allows for continuous patient monitoring and data continuity. Flexible design allows for a multi-parameter module with hemodynamic measurements and one additional single-width measurement module.
Transportable and affordable, the CARESCAPE Monitor B450 has been designed with emergency departments and surgery centers in mind.
FORUMSView All (7)
1Reply7 months ago | ERROR Code 0xHOST1005 I am receiving an error code "0xHOST1005". I cannot find this code in any GE service manual or website. Does anyone know what this error code means, or what might be causing it. Thank you! Equipment: GE HEALTHCARE CARESCAPE B450 Reply |
0Replies7 months ago | Replacing CPU Timekeeper Battery It's been over 5 years for my CPU battery to be replaced. It wasn't giving the service error code - I'm just following PM procedure. Now that I've replaced the CR2032, it is now giving that error code and won't clear even if I try changing the time. Has anyone else experienced this? Any tricks? Reply |
1Reply9 months ago | Beat Volume reseting Wondering why beat volume resets to 2 every time unit is turned off/on. I change settings to 8, but goes back to 2 every time. Reply |
Height | 20 cm |
Length | 39.7 cm |
Weight | 5 kg |
Width | 30 cm |
