Ultrasonic Cleaner
Crest CP1800T Powersonic Ultrasonic Cleaner is the perfect tabletop unit for large cleaning applications that don't necessarily require a lot of depth, such as cleaning circuit boards and other wide, flat objects.
- Sweep Frequency 45 kHz
- Analog Timer
- Main on/off switch
- SS Drain Valve
- All stainless steel enclosures resist chemical spills and will not crack
- All timers have continuous operation
- Ceramically Enhanced Transducers
| Height | 14.5 in |
| Length | 21 in |
| Weight | 39 lbs |
| Width | 12.75 in |
- Inside Tank Dimension: 19.5 x 11.75 x 6 inches (LxWxH)
- Tank Capacity: 5 gallons
- Frequency: 45 kHz or 132 kHz ultrasonics
- Removable 6 ft. power cord
- 3 language control panel (German, English and French)
- Ceramically Enhanced Industrial Transducers for greater power conversion at less wattage (3/4 gallon and larger)
- Lifting Handles (3/4 gallon and larger)
- available in either 117V or 230V - at the same price
- Heavy Duty mesh basket with unique folding drain handles available
- 2 year parts and labor warranty
- All stainless steel construction
- Lift off cover included
- Drain with flow control valve
