CPAC - Cox 6000
by CPAC
Cox dry heat sterilizers utilize dry heat rather than steam and pressure to sterilize tools and equipment. This helps to prevent the instruments from corroding, dulling, or pitting. These sterilizers also have 3 sterilization cycles: 6 minute cycles for unwrapped instruments, 8 minute cylces for hand pieces and medical drills, and 12 minute cycles for packaged instruments.
[list] [*] Instrument basket easily slides in and out of chamber. [*] Hinged door folds down and comes equipped with door locking mechanism. [*] Instrument basket can be safely removed and transported with newly designed tool. [*] Taller opening for easier access to heating chamber. [*] High temperature door gasket provides tight seal preventing heat loss. [*] Door interrupt switch. [/list]
| Chamber Width | 8.25 in |
| Height | 15 in |
| Chamber Height | 1.5 km |
| Length | 17 in |
| Orientation | Benchtop |
| Power Requirements | 100-120 VAC |
| Weight | 50 lbs |
| Chamber Depth | 7.5 in |
| Width | 17 in |
Sterilization Temperature: 375º F (190º C)
