Tuttnauer - EZ9P
by Tuttnauer
Closed Door System Fully Automatic Autoclaves
The Tuttnauer EZ9P fully automatic autoclave will fill, sterilize, exhaust and dry at the touch of a button.
-ndds1
a year ago
High Temp Errors
Hello to everyone.
I'm new here and just signed up to this forum.
I have a question in hope that anyone here can help me to deal with my Tuttnauer EZ9 High Temp Errors.
My unit could heat up to 270 degrees and then when it started the sterilization cycle, the temperature the pressure could go up to about 4psi, but the temperature continued to rise to 275 and the unit displayed High Temp and it aborted.
I had opened up all the 3 of the 4 valves (the bottom most inward I couldn't remove it) to clean up everything to make sure nothing was blocked and the plunger was in a working order. I replaced with a new Temperature Sensor and a new Relay but the unit not working. The water pump is working and it pumps water to the chamber so it is not the issue with not having enough water in the chamber.
At this point I have no clue what I could do next to fix this issue. I hope someone on this forum can help me to point out what I should do next.
Thanks in Advance!
-Dan
Equipment: Tuttnauer - EZ9P
[list]      [*] Closed door active drying system to maintain sterility and ensure efficient drying of packs and pouches      [*] High efficiency air pump circulates hot air after the sterilization cycle for fast drying      [*] Hepa filter 0.2 µm air filter (replaceable)      [*] Pre-loaded cycles for: unwrapped instruments, wrapped/packs, glassware and additional drying cycle      [*] All program parameters can be customized and stored      [*] Automatic shut off at the end of both the sterilization and dry cycles      [*] Audible and visual cycle interruption alert      [*] Double safety locking device prevents door from opening while chamber is pressurized      [*] Low water sensor prevents activation of sterilization cycle when there is insufficient water in the chamber or reservoir      [*] Constant monitoring of temperature and pressure for sterilization      [*] Power outage recovery system      [*] Door design prevents steam from coming in contact with control panel      [*] 510k clearance for dental handpieces      [*] Drain valve is located on the front, allowing for quick and easy draining of water reservoir      [/list]
Internal Diameter9 in
Height14.4 in
Length 21.5 in
OrientationBenchtop
Power Requirements110/120 VAC
Weight85 lbs
Chamber Depth18 in
Width20 in
