Coherent - VersaPulse VP
by Coherent
VP Cosmetic Laser
The Coherent VersaPluse VP Cosmetic Laser
FORUMSView All (3)
-AWrongName
2 years ago
GUI Doesn't start up.
The Laser unit I have has a problem where it does start up and get to the self tests, but then shuts itself down again (by the power contactor being opened), as it tests the NVRAM. If I hold the start key in the II position it does continue but doesn't get further than ROM CRC. I have the german version of the ROMs installed which have a line break error in the title text so I'm not sure if it passes the ROM test as the PASS text doesn't line up with the test items. The error it shows sais: "Fehler gefunden: 220 499 501" ("Fehler gefunden:" translates to "error found:") anybody got a clue as to what could be the problem? Or maybe a service manual available? The controller board inside my laser is the Coheren Medical Vegas Controller Brd ASSY 0627-812- (then on a paper label) 01 433Reply
-Valio
4 years ago
Service manual
Hello, I am looking for a service manual of Coherent VersaPulse vascular. Please write me to simeonov.valentin@gmail.com ThanksReply
-Dr L Daman
7 years ago
coherent versapulse vp cosmettic laser leaks water during procedure
my coherent vp cosmetic laser passes all the screen tests whenturned on,operates ok but leaks water from the right rear base of the machine. There is also a pumping sound , as if a hydraulic is working ... Any explanations for this? also, how do you take off the cover on the machine.....iss there a special tool??? how do I get a service manual for this laser ???? thanks, L, A,Daman MDReply
[list]      [*] Touch Screen Control Panel      [*] Laser Footswitch with built-in Repetition Mode      [*] Treats a wide range of vascular conditions      [*] Patented Chill-Tip delivery system with 9mm square spot      [*] Solid state recirculating chiller      [/list]
Laser TypeHo:Yag
Wavelength800 mm
