Fisher and Paykel Healthcare - AIRVO 2
by Fisher and Paykel Healthcare
Humidifier with integrated flow generator
The AIRVO™ 2 sets a new standard for delivering Nasal High Flow therapy to patients, providing performance and convenience with its integrated flow generator and innovative oxygen delivery system.        The AIRVO 2 has been designed specifically to be an integrated solution for delivering Nasal High Flow with Optiflow. Fisher and Paykel Healthcare's leading humidification allows the AIRVO 2 to comfortably provide high flow of air/oxygen mixtures to spontaneously breathing patients, through the unique Optiflow nasal interface.
FORUMSView All (12)
-PIETRO-MONTALTO
a year ago
PIETRO MONTALTO
L'umidifigatore /fisher-and-paykel-healthcare-airvo-2 da un errore 105 mentre un altro da errore 103 a che componente guasto si riferisce il codice di errore?
The /fisher-and-paykel-healthcare-airvo-2 humidifier gives an error 105 while another gives an error 103. Which faulty component does the error code refer to?
-Caretaker
2 years ago
New User
Are the ports on the tubing interchangeable with CPAP cannulas/mask? Can you add to the length of tubing?
-rees
3 years ago
maintenance message
unit comes up with "maintenance" message, what does it want/need to be done
VIDEOS
AIRVO 2 Video Guide Part 4: Cl...
AIRVO 2 Video Guide Part 3: Us...
AIRVO 2 Video Guide Part 2: Se...
AIRVO 2 Video Guide Part 1: In...
[list]    [*] Optiflow Nasal Interface - Soft, flexible prongs that contour to the patients nose    [*] Heated breathing tube - Dual spiral heater wires and unique integrated temperature sensor    [*] Designed for simple setup, use and cleaning - helpful inscreen animations assist with setup and troubleshooting    [*] Adjustable temperature and flow settings - Three temperature settings help achieve comfort and compliance    [*] Supplementary oxygen - Oxygen can be added from a wall supply or cylinder    [/list]
Height175 mm
Length 295 mm
Weight2.2 kg
Width170 mm
