Heraeus - Biofuge Fresco
by Heraeus
Compact, Fast, and Quiet
Create space in your laboratory. Take advantage of the small footprint which can be integrated into any work-place. The brushless induction motor runs quietly. In 15 seconds or less, the rotor accelerates to 16,000 x g, which is sufficient for all standard applications. A "quick run" key is used for short processing runs. The high-powered refrigeration unit of the Biofuge Fresco with stand by cooling ensures temperatures beneath 0° C even at maximum speed.                    The smooth design of the casing and the modern keypad control are easy-to-clean. The straightforward arrangement of the keys, with icon labels and the EASYcontrol microprocessor controller, make it simple to operate. One-touch lid opening allows for easy access to the rotor.
[list]          [*] The smallest refrigerated centrifuge for microltre tubes          [*] Ultra-quiet standstill cooling          [*] Powerful CFC-free refrigeration unitl          [*] Aerosol tight :East-Twist-On" lid          [/list]
Height305 mm
Length 450 mm
OrientationBenchtop
Weight59.4 lbs
Maximum Speed13000 rpm
Width290 mm
[list]    Max RCF: 16,060 x g    Max Capacity:    - 24 x 1.5/2 ml or    - 4 PCR-strips or    - 32 individual PCR-tubes    [/list]
