Nihon Kohden - GF-210R/GF-220R
by Nihon Kohden
Nihon Kohden GF-210R/GF-220R anesthetic and respiration gas monitor.
2RepliesThu Jun 06 2024 | mac adjustment can this analyzer calculate age adjusted MAC? aka pediatric age adjustments vs adult. thanks Reply |
3RepliesWed Apr 11 2018 | Cal Gas Has anyone purchased Cal Gas for the GF-210R from Scott Medical? If so, do you have a part # available? Thank you.Reply |
0RepliesTue Oct 24 2017 | Power light Hello! Does anyone knows if the unit can be powered on without being attached to a bedside monitor? I don't have the connection cable here, and when I try to power on the multi gas unit, there's no sign of power, the light stays off. Reply |
[list] [*] Respiration gas concentration measurement [*] Respiration volume measurement (GF-220R) [*] Mainly used in the operating room [*] Continuous monitoring of O2, CO2, N2O and volatile anesthetic agents (halothane, enflurane, isoflurane,sevoflurane, and desflurane) Continuous monitoring of airway flow rate, airway pressure and airway volume (GF-220R only) [*] Expiratory and inspiratory phases of respiration from momentary concentrations [*] Calculates the rate of respiration and determines the concentration of each component during inspiration and at exhalation [*] Automatic identification of five anesthetic agents [*] Fast measurement just 60 seconds after turning the power on [*] Small sampling flow rate of 200 mL/minute allows measurement of volatile anesthetics and is useful for neonatal monitoring [*] Automatic or user-set flow rate [*] Can be mounted horizontally or vertically [/list]
