Covidien - OptiVantage DH
by Covidien
Fully programmable at the remote console, allowing technologists to change protocols and more.
The RFID-enabled system creates an intelligent interface between the contrast media syringe and the power injector that helps radiology technologists to better ensure that each patient receives the prescribed concentration and programmed dose of a contrast media-related drug during a procedure. The interface allows the injector to physically alter the RFID label on a syringe once it is used, which can substantially reduce the probability of life-threatening air injections or air embolisms caused from using an empty, used syringe. It also helps reduce the potential for infection from cross-contamination by automatically preventing the injection of contents from a previously used RFID-labeled syringe in another patient exam. Covidien's system also indicates if the drug in an RFID-labeled syringe is past its expiration date. Additionally, the system automatically transfers drug and achieved exam protocol information onto a printed label for the patient record, which reduces the need for manual data entry, thereby offering the potential to help increase efficiency and accuracy.
FORUMSView All (16)
-sergio SERGIO SERGIO
a month ago
0x2004
Dear Srs, I have an injection Mallinckrodt Optivantage DH who is presenting the following errors: alarm ! 0 x 2004 Could anyone help me?Reply
a month ago
alarm 0x2004
Dear Srs, I have an injection Mallinckrodt Optivantage DH who is presenting the following errors: Alarm ! 0 x 2004 Could anyone help me?Reply
2
-lili96
2 months ago
TOUCHSCREEN CALIBRATION
Can anyone tell me how to calibrate the touchscreen, please?Reply
SERVICE COMPANIESView All Contrast Media-Injector System Companies
  • Fully Programmable Powerhead
  • Enables the technologist to stay with the patient longer.
  • Powerhead features provide the ultimate in user-friendly operation.
  • Saline can be programmed to inject prior to, or immediately following, contrast.
  • Sleek and streamlined design for ergonomic convenience.
  • All programming can also be achieved in the control room at the remote console.
  • Perform a saline flush first to check for patent veins, and correct placement of the cannula,prior to contrast injection.
  • Stay at patient’s side while testing.
  • Perform a Timing Bolus injection of contrast medium followed by a saline flush to determine ideal scan delay for optimum image quality.
Injector Syringe ConfigurationDual
Flow Rate: 0.1-10.0 ml/sec
Pressure Limit: 50 -325 psi
Syringe Sizes: 200 ml empty syringes
50, 75, 100, 125 ml high pressure prefilled syringes
