MedRad - Stellant D
by MedRad
Provides saline flush apabilities and robust protocol options for the most advanced clinical applications.
Stellant D CT injector is a full-featured, dual syringe injection system that enables clinicians to perform the most critical CT contrast exams, including Cardiac CT and Coronary CTA. Stellant D with DualFlow gives you control of contrast enhancement in both sides of the heart and in the coronary arteries. Find out more about DualFlow or read new research showing the clinical advantages of Stellant D and DualFlow.
Because it is a dedicated, dual-head CT injection system, Stellant D allows you programming flexibility, including the exclusive ability to use saline before AND after contrast. From Saline test injection to timing boluses, Stellant D expands the number of protocols available to you with a single CT injector. Stellant D introduces saline flush capability for CT imaging sites that need to produce optimal images using the most advanced clinical applications, such as those for Cardiac Angio and CTA.Stellant D also provides intuitive automation and convenience features that can lead to reduced setup times and shortened overall scan times.
1Reply18 days ago | touch screen touch screen on monitor not working , is there a solution to use mouse and keyboard or another touch screen external Reply |
0Replies2 months ago | error-num -311 Hi, do you know what mean the error-num -311 with a Sym Code SW. Reply |
1Reply7 months ago | Swift ans spare parts Hi, I would like to purchase swift and spare parts for Medrad equipment specifically Stallant D and SSEP. Equipment: MedRad - Stellant D Reply |
Injector Syringe Configuration | Dual |
Modality Compatibililty | CT |
