MAQUET - ALPHAMAQUET 1150
by MAQUET
Comprises a seat section and a lower back plate for modular assembly to suit a number of surgical disciplines.
With an installed base of over 13.000 operating tables, ALPHAMAQUET 1150 has proven its reliability and versatility in many situations.    The operating table is the heart of an efficient circulation concept for the surgical suite. Beginning with the patient transfer unit and continuing through the anaesthesia induction room and the OR, followed up by mechanical decontamination for the table top – we offer all the equipment needed, all from a single source.    Operating table columns in two performance classes can be combined with a wide variety of both special and all-purpose table tops. The programme is rounded out with easily manoeuvrable transporters.    A tailor-made configuration can be set up, for every intervention and for every need, drawing upon the building blocks in this modular system. The result is a workplace for the surgical staff which simply leaves nothing to be desired in terms of flexibility, user ergonomics and economy.    ALPHAMAQUET 1150 sets standards in terms of both flexibility and stability. The operating table system bears patients with a weight of up to 225 kg (plus 20 kg accessories) and, under certain circumstances, even up to 360 kg.
FORUMSView All (4)
-Joao Torres
5 months ago
Floor attache
Can someone help me and give the tech data for the floor support? I need to replace and I want cover the flor, I would like to know what is in the hole, thanks
-mehrdad3973
8 years ago
Doesn't work
The 1150 maquet or table doesn't work property and it makes a beep when I press the ON button on over ride panel. I'm sure that power supplies are OK. Please help me.Reply
-mehrdad3973
8 years ago
Maquet 1150
It doesn't work . Just makes a beep. I checked all DC Voltages and they are present.Reply
Stability  ALPHAMAQUET 1150 sets standards in terms of stability. The operating table system bears patients with a weight of up to 225 kg (plus 20 kg accessories) and, under certain circumstances, even up to 360 kg.    Flexibility  Operating table columns in two performance classes can be combined with a wide variety of both special and all-purpose table tops.    High-quality surfaces  All parts are made of stainless steel and electrolytically polished, making them smoother. As a result, the surfaces are more hygienic and less porous.    Simple machine cleaning  The table top and transporter as well as all accessories for the washable model may be machine decontaminated, thus ensuring the highest hygiene standards.
SERIES MODELS
Getinge - 1150.16 Table-Top
Getinge - 1150.19 Universal Table-Top II
Getinge - 1150.20 Universal Table-Top
Getinge - 1150.23 Table-Top
Getinge - 1150.30 Universal Table-Top
