Valleylab - LigaSure
by Valleylab
The LigaSure™ vessel sealing system gives you something no other electrosurgical tool can - permanent vessel occlusion. The LigaSure™ system's revolutionary technology replaces almost all other hemostatic tools because it doesn't just ligate vessels, it actually fuses vessel walls to create a permanent seal.
1ReplySat Sep 27 2025 | usermanual ? user manual Reply |
8RepliesThu Jan 18 2024 | Valleylab - LigaSure lacks power Hello all, Our ligasure is not giving any alarm or error code of any kind, works the same way it usually does, but is less powerful than before. Any idea what the issue could be? Thank you! Reply |
5RepliesWed Apr 28 2021 | Need operation manual .Does anyone have access to the owners manual for this machine? To clarify, the manual on MedWrench is for the force triad system, I am need just the ligasure system. Would be willing to purchase if needed or pdf would be best. Thanks. Reply |
| Height | 5 in |
| Length | 16 in |
| Weight | 13 lbs |
| OutPut Frequency | 473 kHz |
| Width | 15.2 in |
