CAS Medical - 750
by CAS Medical
At just 4.4 lbs (2kg), the 750 is one of the world's smallest and lightest multi-parameter monitors.
At 2kg (4.4 lbs), the CASMED 750 is one of the world’s smallest and lightest multi-parameter monitors.
Compact and technologically advanced, the 750 is ideal for:
  1. procedural sedation
  2. transport
  3. in-hospital applications
  4. emergency care
  5. outpatient care
  6. all patients including adult, pediatric and neonatal
FORUMSView All (4)
-DrSteve52
6 years ago
No Sound for monitor. CAS 750
I have a Cardell veterinary monitor 9405 which appears identical to a CASMED 750 unit. The unit stopped producing any sound at all a few months ago. When first turned on it should produce 3 beeps but doesn't. All else appears to be functioning ok. Is this likely the speaker or something more involved? Thoughts? I do not see anything like this in the service manuals. Thank you.Reply
-dr.webster@tampavet.com
8 years ago
ECG errors
ECG Errors
I turned the machine on and off. Unplugged and plugged back in ECG plug, leads, and placed on and off patient again. I cannot get it to work.
What other things can I try?
-jhorgan
9 years ago
NASAL CANNULAS
Can you use salter cannulas instead of the micro stream cannulas?
  • Fully configured monitor includes ECG (3 or 5 lead), respiration, temperature       and impedance respiration, SpO2, NIBP and EtCO2
  • Pulse oximetry choices including Masimo SET® and Nellcor® OxiMax®
  • CASMED’s proprietary Motion Artifact Extraction (MAXNIBP®) technology for       fast, accurate and reliable blood pressure measurements
  • Oridion Microstream® EtCO2 option for intubated and non-intubated patients
  • Wireless (infrared) printer option
  • User removable NiMH battery pack, internal power supply and DC power        option
Weight4.4 lbs
Display:
• Up to three waveforms
• Grouped numerics
• Trend and alarm history
750E Configuration:
750E-1 ECG
750E-2 ECG and SpO2
750E-3 ECG, SpO2 and MAXNIBP
750E-3C ECG, SpO2 and EtCO2
750E-4 ECG, SpO2, MAXNIBP and EtCO2
750C Configuration:
750C-2 EtCO2 and SpO2
750C-3 EtCO2, SpO2 and MAXNIBP
