Instrumentation Laboratory - GEM Premier 3000
Your Reliable Blood Testing InstrumentFor quick blood analysis, delivery and reliable results look no further than the GEM Premier 3000 which can be used in laboratories, medical centers and healthcare outfits. The device utilizes disposable multi-use cartridges that contain sensors, reagents, solutions and tubing that are maintenance free. It is advised you change the cartridge every three weeks for maintenance and to achieve a longer life cycle for your device.
FORUMSView All (17)
2Replies3 years ago | manual user operation manualReply |
0Replies6 years ago | ABG GEM3000 SCREEN IS SHOWING HAULTED WHAT TO DO Reply |
0Replies9 years ago | EQUIPO INESTABLE EL EQUIPO PRESENTA ERROR DE SOFWARE 3.05 EN CIERTOS MOMENTOS Y NO SABEMOS PORQUE Reply |
- Flexible test menu includes pH, pO2, pCO2, hematocrit, electrolytes and metabolites
- Disposable multi-use cartridge contains everything you need: sensors, solutions, waste bag, tubing, even the sampler
- Maintenance-free — just replace the cartridge every three weeks
iQM, IL's proprietary Intelligent Quality Management system, performs continuous quality control - GEMweb® software provides access to any networked analyzer to view results, monitor performance and deploy standard configurations
Height | 43.2 cm |
Length | 30.7 cm |
Weight | 13.4 kg |
Width | 30.5 cm |
NEWSView All
Device Alert
Instrumentation Laboratory GmbH has issued an information that the package inserts for certain product lots of GEM Check Coag Whole Blood Controls contain incorrect data. Instrumentation Laboratory—GEM Check Coag Whole Blood Controls: Package Insert May Contain Incorrect Acceptable Performance Range See attached PDF under Manuals & Resource ...
