Eschweiler - modular PRO
New PC-based generation of analysing systems: compact, fully modular, easy and economical.With the clear functionality the ESCHWEILER modular PRO is dedicated to serve you. In critical cases even seconds count. We follow this obligation. With its clear and easy handling the ESCHWEILER modular PRO provides fast and accurate results to give you the required informations for your further actions. The unlimited flexibility of our new concept is a big advantage for you. Choose only those parameters which are of interest for you - any combination out of 11 parameters is allowed. Even if your workload is changed and new parameters are useful just expand the system with the channels you need. We save your money for unnecessary investments and costs for operation and maintenance of sensors which are not required.
[list] Barcode reader [*] Input of calibration bag-codes (concentrations) [*] Input of encoded patient data [*] Input of encoded QC samples Network (LAN) [*] Connection of ESCHWEILER modular PRO to the clinic-internal network via LAN-interface [*] Taking over of patient- and QC-data via ODBC (open database connectivity) [*] Easy to use, clear step-by-step instructions [*] Service- and diagnosis programs for faultless operation [*] Data base for patient- and QC-data storage and evaluation [*] Only 4 calibration solutions and a rinse solution to operate an ESCHWEILER modular PRO with complete sensor configuration for analysis of blood gases, electrolytes and metabolites [*] Only 2 calibration solutions for analysers with sensor combination “blood gases”, “electrolytes” or “metabolites” [/list]
Height | 400 mm |
Length | 413 mm |
Weight | 18 kg |
Width | 445 mm |
Display: Color-LCD-display (TFT- 640 x 480)
