Bowa Electronic GmbH - Arc Plus
by Bowa Electronic GmbH
With its argon plasma coagulation technology, the ARC PLUS is the ideal supplement to the ARC generator range.
With its argon plasma coagulation technology, the ARC PLUS is the ideal supplement to the ARC generator range. Argon-assisted spray coagulation can even work reliably with arcs in the extremely low power range of less than 10 Watts. As a result of their low coagulation depth, they only cause minimal necrosis of the tissue, which favours their use in areas at risk of perforation.
Two ranges are available for the use of different argon accessories: Argon and Argon-Flex.
