Eschmann - TD830
by Eschmann
[b]Two generators in one electrosurgery unit[/b] Bipolar and monopolar outputs are available simultaneously and work independently of each other. In addition a second monopolar output is available on a first come first served basis. [b]For outstanding performance in electrosurgery[/b] TD830 bipolar and monopolar generators provide cutting and coagulation output modes; each is easy to use, giving optimal speed and precision which is essential when the minimisation of tissue damage is a priority. [b]Designed for ease of use[/b] The simple clear colour coded front panel enables the user to select monopolar and bipolar modes at the touch of a button. The pull-out card in the bottom of the unit gives guidance on basic set up and fault conditions, ensuring training requirements are kept to a minimum in busy operating theatres. The front panel alarm identification will illuminate to prompt corrective action should a fault condition arise. [b]Safety first for the patient and operator[/b] Eschmann have always known that safety is of key importance. As such the TD830 electrosurgery unit has been designed to incorporate advanced safety monitors which work together to minimise the risk to the patient, surgeon and theatre staff. These include Patient Continuity, Plate Attachment (divided plates), Patient Earth, Plate Voltage and Excess Power Monitors. [b]Comprehensive after-sales service for peace of mind[/b] For complete peace of mind, Eschmann after sales service department offer a comprehensive service providing the reassurance of a fast response in the unlikely event of a problem with your equipment.
1ReplyWed Jan 26 2022 | Unknown Error Dear All i have an issue with the Eschmann - TD830 , the buzzer is always On , when you press the footswitch it goes silent and a red Lamp Indicator --> " ! " is on all the time. Any idea what might causing this issue? Reply |
1ReplyWed May 03 2017 | part number of main boarde what is the part number of main boardeReply |
0RepliesMon Oct 17 2016 | usefulness of ESCHMANN in infertlity centres In what ways has ESCHMANN product been useful in fertility centres and the maintenance packages Reply |
| Weight | 14 kg |
| OutPut Frequency | 475 kHz Monopolar |
