Tanita - TBF-300WAPlus
Wrestling Body Composition AnalyzerTanitas commitment to the wrestling community is solidified with the FDA cleared TBF-300WAplus Wrestler Mode Body Composition Analyzer. Striving to provide the most accurate body composition assessments available through modern science, the TBF-300WAplus allows you to educate your student wrestlers on the Minimum Wrestling Weight (MWW) allowed while maintaining a healthy body fat percentage. The minimum percent body fat values used to calculate the MWW are derived from the 1996 American College of Sports Medicine (ACSM) Position Stand Weight Loss in Wrestlers, that has been adopted by the National Collegiate Athletic Association (NCAA) in their 1998 Weight Management Guidelines. Preset with both Collegiate and High School minimum body fat percentile standards gives you the ability use the same machine for any weight class of wrestlers. Building on the success of its predecessor (the TBF-300WA) the new TBF-300WAplus provides an increased weight capacity on a new and improved large / low profile platform along with enhanced outputs of RS-232 and USB. The printed reported now provides a more detailed analysis of the results, making it easier for you to explain to your wrestlers. It delivers fast and accurate results, saving you time and helping to promote safe and optimal conditioning using the latest FDA cleared non-invasive bioelectric impedance analysis (BIA) technology. And like all Tanita body composition monitors, the TBF-300WAplus does not require any special and costly forms for printing, standard rolls of thermal paper keep your on-going cost of ownership low.
- Direct replacement to the TBF-300WA
- The standard in bioelectric impedance for the wrestling community
- Quickly and accurately determines minimum wrestling weight
- Collegiate body fat threshold 5%, high school body fat threshold 7%
- On-board printing, no special/costly paper forms required
- Portable design can be easily transported to meets
Length | 15.6 in |
Weight | 18.3 lbs |
Kind | Standing |
Width | 15.3 in |
Capacity: 600 lbs
