Tanita - BWB-800P
by Tanita
This economical, column-mounted digital scale has a lightweight, yet durable construction and an easy-to-read 1.1" LCD display. The BWB-800P physician scale also has an instant lb/kg switch, auto center zero, weight lock and a high-capacity platform. The elevated height of the display and one piece construction are well suited for areas with space constrictions. The BWB-800P can be operated on batteries, or with the supplied AC adapter.
[list] [*] Durable construction, full metal platform will withstand heavy use [*] 440 pound weight capacity, great all purpose scale [*] Column mounted display provides for convenient viewing [*] Battery powered option, eliminates potential trip hazard [*] Oversized LCD display is easy to read [/list]
| Length | 13.3 in |
| Weight | 17.5 lbs |
| Kind | Standing |
| Width | 11.8 in |
Capacity: 440 lbs
