Tanita - WB-8000RW
by Tanita
Radio Wireless Professional Weight Scale
From the innovators in scale radio wireless technology, the WB-8000RW from Tanita combines all of our industry leading technologies into one package. From the gym, to the clinic, to the hospital, this scale has best-in-class features to meet any need: oversized platform, high weight capacity, low profile, radio wireless, portability, and best of all the durability and accuracy you've come to expect from Tanita. The large platform, nearly 300 square inches of surface area, coupled with a low step-up height under 2 inches make it an ideal scale for bariatric, geriatric, and acute care applications. Heavy gauge steel frame construction under the rugged ABS plastic platform is designed to provide years of accurate measurements. The built-in handle and optional battery operation provides unsurpassed mobility.            The radio wireless feature means no more cables to trip over and the freedom to position the scale anywhere within your facility.            Wirelessly transmit weight and BMI data to the Tanita D-8000 remote display (sold separately) or Tanita HealthWare software (sold separately). This software can be used to record and analyze, or export to excel or .csv data for use in other medical record software programs, or directly to EMR compatible software. Good for a range of up to 30 feet (300 feet with the optional WiFi Network Adapter), theWB-8000RW uses radio wireless technology to provide secure communications between the scale and the remote device, USB ANT+ stick (included) and driver will be required for use with PC. Pairing of the scale and remote device further enhances security of data transmissions.
[list]      [*] World’s first radio wireless professional weight scale      [*] Ultra-high capacity of 660 pounds      [*] Oversized platform      [*] Heavy duty steel frame design for years of constant use      [*] No display on platform, the ultimate in discretion and security      [/list]
Length 19.9 in
Weight16.3 lbs
KindStanding
Width14.4 in
Capacity: 660 lbs
