Tanita - PH-740
by Tanita
Handrail Scale
The Tanita PH-740 is the next generation in acute care scales. This handrail scale incorporates state-of-the-art technology within the most user-friendly package in the industry. With a capacity of 1,000 lb (450 kg), this scale can accommodate every clinical need. Its extra-wide, low-profile platform make it perfectly suited for patients that have trouble stepping up and onto traditional physician scales. The built-in height rod and automatic BMI calculator are real time savers.            Castors on the base of the PH-740 platform allow it to be moved with ease. It also features a mechanical height rod, allowing patients height to be taken along with weight. Requiring no tools for assembly, the modular design makes for simple on-site assembly and service, should you ever need it.            EMR ready with both an RS-232 and USB output. When used with Tanita HealthWare Software (sold separately) data from the PH-740 can be stored on PC to provide custom recording, tracking, and analysis for an unlimited number of users.
-bkmedical
4 years ago
CALIBRATION
Does anyone have the manual/procedure to calibrate this model # on the Tanita scale Thanks Reply
[list]      [*] Industry's highest capacity, 1,000 pounds!      [*] Instant on, no buttons to push      [*] Wide platform with gentle pitched corners, perfect for those limited mobility      [*] Rugged design for years of constant use in high traffic environments      [*] Digital outputs are EMR ready      [/list]
Length 26.3 in
Weight61.7 lbs
KindStanding
Width22.5 in
Capacity: 1000 lbs
