Tanita - 1583
by Tanita
The battery-conserving LCD gives accurate measurements in 10-gram increments when you need it most. At just 6 lbs, the 1583 is perfect for at-home weighing and visiting nurses alike. Weight lock-in, low battery indicator and tare weighing standard. Removable tray for easy cleaning.
[list] [*] LCD display conserves energy for extended battery life [*] Weighs only 6 pounds, perfect for in home and visiting nurses [*] Removable tray for easy cleaning [*] Weight lock-in feature for easy viewing of results [*] 0.5 oz (10 g) resolution up to 20 pounds [/list]
| Length | 12.7 in |
| Weight | 6.2 lbs |
| Kind | Infant |
| Width | 21.5 in |
Capacity: 40 lbs
