IMT Analytics - FlowAnalyser PF-300
by IMT Analytics
Analyser Measurement & Simulator
Test, verify and calibrate any kind of medical device that generates pressure or produces flow such as ventilators, respirators and anaesthesia machines.
The FlowAnalyser measures bi-direction flow, various pressures, temperature, humidity and O2 concentrations. The unique measuring modes for adult, pediatric and high frequency ventilators decreases test duration significantly. It incorporates remote control interface, data storage, internal battery and the high-end PC-based Software tool FlowLab.
Accuracy of flow with less than 1.75 % deviation of reading. Two channels 0..20 and 0..300 Liter per minute.
| Battery Analyzer | 0 |
| Height | 12 cm |
| Length | 25 cm |
| Weight | 3.7 kg |
| Analyzer/Simulator Type | Gas Flow |
| Voltage Range | 50 to 60 Hz |
| Width | 22 cm |
