IMT Analytics - CITREX H5
Analyzer Measurement & Simulator
The CITREX H5 gas flow and pressure gauge offers the most advanced user interface for demanding applications on a high-resolution 4.3 inch multi-touch screen. It is portable, precise and as a user, you can customize the measurement screens to suit your needs. The CITREX H5 is designed to support you in a variety of daily applications. Thanks to its precision and reliability, you can use the CITREX H5 to test a wide range of medical devices such as respiratory and anesthesia devices, oxygen flow meters, pressure gauges and suction devices.
- Display the ventilation parameters graphically
- Check the oxygen concentration quickly and uncomplicated
- Compatible with a large number of gas standards and gas types
- Always have the correct measurements at hand
Battery Analyzer | 0 |
Height | 7.3 cm |
Length | 7 cm |
Weight | 0.52 kg |
Analyzer/Simulator Type | Gas Flow |
Voltage Range | 50 to 60 Hz |
Width | 11.4 cm |
Various interfaces (WI-FI, USB, RS-232, TTL, ETHERNET, CAN)
Scope of delivery:
CITREX H5, oxygen sensor, SmartLung adult, FlowLab
software incl. activation code, monitoring
extension for webserver, carrying bag, laminar
flow tube, USB car adapt- er, USB cable, power supply,
ethernet cable, adapter-set, protection filter, CITREX H5
Protector.
NEWSView All
CITREX H5 Provides Device Calibration
CITREX H5 is an all-in-one ventilator analyzer solution enabling medical technicians, independent service providers, anesthetists, and ventilator manufacturers to measure and calibrate devices.
Buy a Ventilator Analyzer and Get 3 Calibrations for Free
The CITREX H5 ventilator analyzer features high precision with maximum adaptability. If you buy one between now and December 31 2017, you will receive: 3 free calibrations including shipping.
