WEM - HF-120
Portable Microprocessed Electrosurgical UnitThe HF-120 high frequency electrosurgical unit has been recognized as the most advanced generator for treating pre-cancer HPV and gynecological lesions. Especially recommended for women's lower tract surgeries. Operates safely and accurately thus avoiding implications on future pregnancies. The HF-120 may be used to perform ambulatory and hospitalar procedures. A smooth cut with high level precision and minimal tissue damage ensures ideal samples for histological exams. Bleeding across large areas may be quickly and superficially cauterized using the SPRAY mode, or specifically for in-depth cauterization using CONTACT mode. Excellent results are assured, for treatment of HPV-induced lesions of Cervical Intraepithelial Neoplasia (CIN); large loop excision of the Transformation Zone (LLETZ/LEEP); and cervix, vagina, vulva and perinatal region biopsies. The HF-120 is also suitable for dermatology, otorhinolaryngology and plastic surgery.
FORUMSView All (3)
0Replies7 years ago | Hf120 dont start whem foot Why this hapen ? Im eletronic tecnician , in hospital i need service manual . Reply |
1Reply10 years ago | distichiasis Is it possible to use this machine to treat distichiae? If so, what setting is best and what 'end piece' Many thanks Reply |
1Reply11 years ago | Short
power suply Reply |
- Fully microprocessed
- Six functions: pure cut, blend 1, blend 2, blend 3, coagulation and bipolar
- Power adjustment through waterproof shielded pushbuttons on front panel
- High-visibility digital display indicates maximum power level for each mode
- Volume adjustment on front panel
- Non-volatile memory
- Double footswitch control and/or handswitch control
- Independent footswitch for bipolar mode (optical version)
- High cut incorporated
- Isolated power outputs to minimize the risk of burn
- PPM patient-plate monitoring system
- Automatic voltage selection
Height | 15 cm |
Length | 26 cm |
Weight | 2.8 kg |
OutPut Frequency | 480 kHz |
Width | 24.5 cm |
- Power supply: 127-220 VAC/ 50-60 Hz - automatic selection
- Excellent results in treating HPV-induced lesions
- Indicated for day surgeries and office
- Special accessories for endoscopy and colonoscopy
- High Cut incorporated
- Non-volatile memory of power levels in all use modes
- Bipolar output
- Insulated power output
- Natural ventilation (convection)
- Independent footswitch for bipolar mode (optional)
