Precision Medical - PM63
Power and intermittent suction in a small packageFORUMSView All
SERVICE COMPANIESView All Aspirator Companies
- High performance 1/5 horsepower pump delivers a suction range of 0-200 mmHg and a full vacuum of 279 mmHg
- Fits into areas where space is at a minimum and is easy to carry
- The unique canister holder is moveable, allowing the caregiver to rotate the canister to either side of the unit for best placement near the point of use
- The plastic cabinet is durable, attractive, easy-to-clean and infection control friendly
- A dual protection system consists of a float shut-off in the canister lid and an Inline Hydrophobic Filter to prevent back flow of fluid as well as airborne contaminants from entering the pump
- The unique design allows a quieter operation for around the clock use
- Has a unique patented modular design regulator. No need to replace the full unit, only the problem module
Height | 10.125 in |
Length | 15.875 in |
Weight | 21.2 lbs |
Vacuum Range | 0 - 200 mmHg |
Width | 67.375 in |
