Burdick - E350
by Burdick
The Burdick E350 has electrically isolated patient leads for patient safety. A self-check of the micro-processor circuitry is performed each time the unit is turned on. Meets all A.H.A specifications for frequency response and leakage current.
1ReplyMon Sep 15 2025 | can I get a user manual online? how the default settings? Equipment: Burdick - E350 Reply |
8RepliesWed Mar 20 2019 | Memory Battery for Burdick E350 ECG machine Hello, I have a Burdick E350 ( not E350i ) ECG machine needs to replace the memory battery because it does not save the date and time. Can someone tell me the memory battery is 3.0 V or 3.6 V Lithium battery? Are they interchangeable? Where is the memory battery located on the board? Is it easy for me to replace? Thanks. JCC M.D.Reply |
[list] [*] A microprocessor based electrocardiograph, designed to produce accurate records with maximum definition and fidelity. [*] Electrically isolated patient leads for patient safety. [*] A self-check of the micro-processor circuitry is performed each time the unit is turned on. [/list]
