Precision Medical - Dial Flowmeters
A new solution for an old problemPrecision Medical Dial Flowmeters
[list] [*] Durable - The lack of a flow tube and the durable metal body prevent the breakage problems long associated with standard flowmeters [*] Compact - Allows the unit to fit into tight headwall areas and makes it virtually damage-proof when other equipment is installed [*] Accurate - Accuracy is assured at every flow setting without the need for a visible float as in thorpe tube flowmeters [*] User-Friendly - The knurled flow adjustment knob and the large easy-to-read numbers make flow adjustment easy [/list]
