Chattanooga - Intelect Legend XT
Intelect Legend XT® SystemElectrotherapy is the application of electrical stimulation transmitted through the body via electrodes for therapeutic purposes. With electrotherapy, the current flows through the body from one electrode to the other and causes different physiological reactions, which are determined by the type of current selected, the parameters of the selected current and the output intensity. The Intelect Legend XT is one of the most advanced therapy systems available. Beneath its award-winning, ergonomic design is a sophisticated, versatile, user-friendly system. The Intelect Legend XT lets you offer a comprehensive range of therapies in a single, state-of-the-art unit.
1Reply4 years ago | user manual where can I find the user manual for the Intelect Legend XTReply |
1Reply4 years ago | Intensity adjustment Working on this unit for my PT. No experience with it. Intensity adjustment does not work at all. The pot for intensity is on the control bd. Worth a try at replacing the board?Reply |
SERVICE COMPANIESView All Electrotherapy Companies
- Easy-to-add modularity allows the addition of two additional channels of electrotherapy or a battery module
- High contrast 5 (13 cm) FSTN LCD monochromatic user interface
- Two independent electrotherapy channels, expandable to four independent channels
- Multiple waveform electrotherapy-six clinical waveforms: Interferential, Premodulated, High Volt, Russian, Symmetrical Biphasic and Microcurrent
- Documentation of treatment data with Patient Data Cards
- User defined protocols for your specific needs
- Therapy System Cart maximizes storage of clinical supplies and organizes cables
- Dual frequency ultrasound at 1 or 3.3 MHz
Pulsed or Continuous Duty Cycles (10%, 20%, 50% & 100%)
Four ergonomically designed soundhead applicator sizes: 1 cm², 2 cm², 5 cm² & 10 cm²
Watertight soundheads for use in underwater therapy
Transcutaneous electrical nerve stimulation (TENS) | YES |
Height | 8.75 in |
Length | 12.75 in |
Weight | 7 lbs |
Width | 11.4 in |
