MAQUET - SERVO-i
Ventilator
SERVO-i® combines a high level of clinical performance for invasive, non-invasive or neurally controlled ventilation with outstanding mobility and cost efficiency. It features all the modes you would expect from an advanced ventilation system in one adaptable platform. Four basic configurations are available: SERVO-i Infant, SERVO-i Adult, and two editions of SERVO-i Universal for all patient categories. SERVO-i Infant and SERVO-i Adult can always be upgraded to SERVO-i Universal. A wealth of features and functionalities for treating adult, pediatric and neonatal patients all in one platform. All SERVO-i ventilatory configurations are effective for bedside use. Unique features and upgrades can be added as your needs change, ensuring dependable performance in the years to come and the best possible return on your investment.
FORUMSView All (16)
1Reply9 months ago | How to change language How to change language Equipment: MAQUET - SERVO-i Reply |
4Repliesa year ago | error 25 Technical error - 25? I want a solution to this problemReply |
3Replies4 years ago | ServoI not starting properly, When powering on the machine it is going direct to the ventilation screen (not standby) and says restart ventilator. Some of the buttons work, some don't. It won't let me go to standby. Powering on and off is not working also took out the batteries with it unplugged and off to see if that would "reset" it no success yet. Ideas? I do have a software card but not sure if it is the same one as the machine has, will that be a problem?Reply |
- Enhanced Interaction - offers unprecedented levels of speed in sensing and control
- Neurally Adjusted Ventilatory Assist (NAVA) - NAVA® is a unique approach to mechanical ventilation as it listens to the patient’s own respiratory signal
- Edi Signal - The Edi signal is a diagnostic tool that monitors the electrical activity of the diaphragm
- Open Lung Tool - Provides an instrument for effectively determining the effect of a ventilator intervention
- Automode - Set a controlled mode and let the ventilator adapt to the current patient situation, switching between controlled and supported breathing in connection with patient effort
- Dimensions: Patient Unit W 300 x D 205 x H 415 mm
- User Interface: W 355 x D 53 x H 295 mm
- Weight: Approx 20 kg
