Allpro Imaging - Scan X Trek
by Allpro Imaging
Perfectly suited for the rigors of work in the field in the ambulatory practice
ScanX Trek is the lightest, most portable and rugged digital imaging system in the industry. Developed exclusively for full body and equine veterinarian by ALLPRO Imaging, ScanX Trek produces high-resolution digital images in as little as 35 seconds. Veterinarians can take more images and make a diagnosis on the spot, while eliminating the need to chemically process X-rays or return to the stable or barn for retakes.        [b][i]Dental imaging product for veterinarians.[/i][/b]
[list]        [*] Built for durability - the cushioned, lightweight extruded aluminum frame helps to resist dents        [*] Non-slip surface - lightweight rigid case protects the scanner during transport        [*] Throughput - scan and erase in a single pass        [*] Robust design - light, portable and rugged – ideal for field applications        [/list]
Height14 in
Length 18 in
Weight44 lbs
Width15.5 in
