Air Techniques - ScanX Intraoral
ScanX Intraoral Digital Radiography System is capable of reading images simultaneously from 4 PSPs in seconds
This centralized intraoral workhorse is an efficient four track system that accepts intraoral PSP sizes 0, 1, 2, 3 and 4 for patients of all ages and anatomies. With ScanX PSPs, you never miss important structures due to their larger, 100% active diagnostic area. This means increased diagnostic capabilities along with greater patient comfort thanks to these wireless, wafer-thin PSPs.
- ScanX delivers crisp, sharp images in up to 18 lp/mm true resolution, meeting the needs of all diagnostic requirements.
- Capture all areas of your patients anatomy thanks to ScanX PSPs that have a 100% active surface area. This means you capture up to nearly 40% more anatomy than with the comparable sized wired sensor.
- Once a PSP has been inserted into ScanX, the sharp, crisp image appears on your screen in seconds.
- Digital images are ready to be reviewed, shared, archived or emailed.
- ScanX PSPs are 30 times thinner then wired sensors; flexible, with rounded corners that provide optimum comfort for your patients.
- Patients and staff are all protected by ScanX barrier envelopes that 100% hygienically seal each PSP.
- A film-like workflow will enable your staff to confidently start using ScanX with virtually no learning curve and will result in fewer retakes.
- The thin, wireless PSPs are durable and immediately ready to be used again thanks to the automatic read and erase technology.
Weight | 44 lbs |
Dimensions (LxWxH): 16"x15.5"x15.5" (40.6cmx39.4cmx39.4cm) Electrical: Universal 100 to 240V, 50/60 Hz
