Air Techniques - ScanX Swift
by Air Techniques
ScanX Swift Digital Radiography System delivers chairside, crystal clear images in seconds
This quick and efficient one track system is capable of reading intraoral PSP sizes 0, 1, and 2 for patients of all ages and anatomies. With ScanX PSPs, you never miss important structures due to their larger, 100&#037 active diagnostic surface area. This means increased diagnostic capabilities along with greater patient comfort thanks to these wireless, wafer-thin PSPs.
SERVICE COMPANIESView All DR Systems Companies
  • Delivers crisp, sharp images in up to 20 lp/mm true resolution
  • 100% active surface area.
  • Capture up to nearly 40% more anatomy than with the comparable sized wired sensor.
  • Crisp image appears on your screen in seconds.
  • Digital images are ready to be reviewed, shared, archived or emailed.
  • PSPs are 30 times thinner then wired sensors; flexible, with rounded corners
Weight14.5 lbs
Weight14.5 lbs
Dimensions (DxWxH): 9.2" x 8.9" x 9.6"
Electrical: 100 to 240VAC +/- 10%, 50/60 Hz
