InnoVet - Versa
Versa is for versatileA broad table design and high-frequency generator can accommodate almost any DICOM compliant digital receptor. So no additional space is required. Versa also comes with an easy-to-use cassette tray that fits a range of cassettes. The unique collimator is easy to operate with gloved hands and also meets the Federal radiation leakage requirement for human applications. The x-ray tube can be lowered to table height and turned a full 90 degrees for standing lateral exams. The x-ray tube and cassette tray move in tandem across the entire length of the table so you can adjust the central ray, not the patient.
[list] [*] Versas encased x-ray tube reduces radiation leakage by over 50%. [*] A unique tube column and tube cover safeguard staff & patients from exposed electrical wires. [*] Rounded corners prevent hip-level bruising common to veterinary technicians. [*] Extended light on time. [*] Its swiveling capability makes table top exams easy. [*] Bulb replacement is done in minutes without the use of tools. [/list]
