ERBE - EIP 2
by ERBE
Irrigation System
The ERBE EIP 2 provides a pulsatile jet of sterile water for rinsing substances such as blood and fecal matter from the procedural site and instruments. product allows delivery of pressurized irrigation for improved visualization in difficult procedures, eliminates bottle and tubing reprocessing. The flow rate display helps facilitate easy changes and the EIP 2 can deliver up to 500 ml / minute.
-biotech klina
Mon Oct 10 2022
Wrong equipment name and manual
Hello, I was suching for information about the Erbe EIP2. I can only find the Erbe ELP2, but i'm convinced the name on your site is incorrect. I have the technical service manual of this device, where can I upload it to you? greatings Joris
Equipment: Erbe EIP2
-bashomeiza_8443
Thu Jul 15 2021
User manual
Please where can I find a user manual to set it up?Reply
  • Works in open endoscopic procedures
  • Uses only disposable ERBEFLO accessories for optimum time savings
  • Pre-set buttons offer customized flow rates
  • Clear flow rate display
  • High volume irrigation
  • Flow rate range 20% (100 ml/min) to 100% (500 ml/min) ± 50 ml/min
  • Pre-sets and adjustment increments 3 pre-set flow rates and 1% increment adjustments
  • Continuous Yes, but for only a maximum time of 20 seconds
  • Width: 8.1" (20.5 cm)
  • Height: 4.9" (12.5 cm)
  • Depth: 6.5" (170 cm)
  • Weight: 6.6 lbs. (3 kg)
  • Rated supply voltage 120 V ± 10%
  • Line current 400 mA
  • Power fuses T 0.4 A
  • Rated supply frequency 50/60 Hz
  • Power input in standby mode 3 Watt
  • Power input with max. HF output 20 Watt
  • Terminal for grounding (potential equalization) Yes
