Techno Medica - GASTAT 602i
High performances of all operationality, accuracy of measurement and functionalityAll models in GASTAT-600 series are equipped with a barcode reader. Through their sophisticated barcode functionality, they automatically indicate when the time has come to exchange the reagents and other consumables. They also collectively manage patient ID and quality control data.
FORUMSView All (5)
1Reply4 years ago | Installation Where can I locate your representative in Nigeria ? Reply |
0Replies7 years ago | Problems in electrode calibration Hi, change all the electrodes of the equipment and when I calibrate it, do not calibrate the ions, which could be. Reply |
0Replies9 years ago | how enter barcode manually hello, how can I enter barcode of pump tube,calcassette,... manually instead of using barcode reader,for example in cases of faulty barcode? thank you in advance for your kind help. Reply |
- Maintenance-free electrodes - The newly-designed long shell life electrodes make a great contribution to high running cost-saving performance They require no maintenance, and provide dependable, high-precision measurements.
- Automatic aspiration system - The automatic aspiration system minimizes the risk of infection during sample loading. The inlet for samples is easily replaced via a one-touch procedure. It accepts samples in either syringe or capillary.
Sample Volume:
-Syringe 100µl (model 600/601); 130µl (model 603ie/604ox)
-Capillary 45µl (model 600/601); 85µl (model 602i/603ie/604ox)
Analysis Time: About 60sec
