STERIS - AMSCO 3080 RL
by STERIS
AMSCO Quantum 3080 RL Surgical Table
The 3080 RL is a good all round general surgery table that combines easy patient positioning, good C-arm access and convenience of use. The 3080 RL also has a proven track record for reliability
FORUMSView All (4)
-Sankd
2 years ago
Need a solution
Have a steris 3080 rl/sp ot table there is issue of glitches when we doing up down moment its not working smoothly Please provide solution
Equipment: STERIS - AMSCO 3080 RL
-shelaA
5 years ago
Part numbers
I have a amsco 3080RL that need the lower, middle and upper shrouds replaced bc the clips are broken. I also need to replace the black plastic upper piece(bellow?)..its not zippered or expanding. I need part numbers for these parts but cannot find a Manual for this model and not sure if the part numbers are the same as the 3085 model. Does anyone know where I can find these part numbers or have a manual?Reply
3
-Bobby S.
6 years ago
Amsco 3080 pump runs continuously
Received a call to the OR and the staff reported the table had a burning smell coming from it. Verified the smell and also found the pump continues to run as soon as you plug it into AC. Removed hand controller and still the pump runs. Checked override switches and foot lock switch under AC receptacle. Looking for suggestions. Reply
  • Great Versatility - Accommodates the most routine laparoscopic procedure to the most demanding orthopedic case to neurosurgery.
  • Simple Operation - Use of the hand control makes positioning the patient very intuitive. Using the “Patient Orientation” button makes positioning the table simple when reversing the patient on the table
  • Absolute Override Protection - Even in the event of a complete power failure and electrical system malfunction on the table, the user can still position the patient or return the table to the neutral position.
Height27 to 44 inches
Length 75.9375 in
Tredelenburg 25 degrees
Lateral Tilt18 degrees
Width20 in
Back Section
  • Down: 25 degrees
  • Up: 55 degrees
Leg Section:
  • Down: 105 degrees
  • Up: 80 degrees
  • Reflex: 20 degrees
  • Flex: 30 degrees
