STERIS - AMSCO 3080 RC
by STERIS
AMSCO Quantum 3080 RC Surgical Table
The 3080 RC is a good all round general surgery table that combines easy patient positioning, good C-arm access and convenience of use. The 3080 RC also has a proven track record for reliability.
-Eric Martin
5 years ago
Service manual
Is there a service manual for this operating table? If so, please send a copy to eric.martin@trimedx.comReply
  • Great Versatility - Accommodates the most routine laparoscopic procedure to the most demanding orthopedic case to neurosurgery.
  • Simple Operation - Use of the hand control makes positioning the patient very intuitive.
  • Absolute Override Protection - Even in the event of a complete power failure and electrical system malfunction on the table, the user can still position the patient or return the table to the neutral position.
Height27 to 44 inches
Length 75.9375 in
Tredelenburg 25 degrees
Lateral Tilt18 degrees
Patient Weight Capacity400 lbs
Width20 in
Back Section
  • Down: 25 degrees
  • Up: 55 degrees
Leg Section
  • Down: 105 degrees
  • Up: 80 degrees
  • Reflex: 120 degrees
  • Flex: 225 degrees
