STERIS - AMSCO 3080 RC
AMSCO Quantum 3080 RC Surgical TableThe 3080 RC is a good all round general surgery table that combines easy patient positioning, good C-arm access and convenience of use. The 3080 RC also has a proven track record for reliability.
1Reply5 years ago | Service manual Is there a service manual for this operating table? If so, please send a copy to eric.martin@trimedx.comReply |
- Great Versatility - Accommodates the most routine laparoscopic procedure to the most demanding orthopedic case to neurosurgery.
- Simple Operation - Use of the hand control makes positioning the patient very intuitive.
- Absolute Override Protection - Even in the event of a complete power failure and electrical system malfunction on the table, the user can still position the patient or return the table to the neutral position.
Height | 27 to 44 inches |
Length | 75.9375 in |
Tredelenburg | 25 degrees |
Lateral Tilt | 18 degrees |
Patient Weight Capacity | 400 lbs |
Width | 20 in |
Back Section
- Down: 25 degrees
- Up: 55 degrees
Leg Section
- Down: 105 degrees
- Up: 80 degrees
- Reflex: 120 degrees
- Flex: 225 degrees
