STERIS - AMSCO 3080 SP
by STERIS
AMSCO Quantum 3080 SP Surgical Table
The 3080 SP is a good all round general surgery table that combines easy patient positioning, good C-arm access and convenience of use. The 3080 SP also has a proven track record for reliability.
-Todd229
6 years ago
Service Manual
Does anyone have a copy of the service manual? Thanks Reply
  • Great Versatility - Accommodates the most routine laparoscopic procedure to the most demanding orthopedic case to neurosurgery
  • Simple Operation - Use of the hand control makes positioning the patient very intuitive. Using the “Patient Orientation” button makes positioning the table simple when reversing the patient on the table.
  • Absolute Override Protection - Even in the event of a complete power failure and electrical system malfunction on the table, the user can still position the patient or return the table to the neutral position.
Height27 to 44 inches
Length 75.9375 in
Tredelenburg 25 degrees
Lateral Tilt18 degrees
Width20 in
Back Section
  • Down: 25 degrees
  • Up: 55 degrees
Leg Section
  • Down: 105 degrees
  • Up: 80 degrees
  • Reflex: 20 degrees
  • Flex: 30 degrees
