Ethicon - 300
by Ethicon
The Harmonic System is indicated for hemostatic cutting and/or coagulation of soft tissue incisions when bleeding control and minimal thermal injury is desired. The Harmonic System instruments can be used as an adjunct to or substitute for electrosurgery, lasers, and steel scalpels. The system utilizes ultrasonic energy.
3RepliesMon Jul 22 2019 | Multiple Errors Hi everyone, i´m new on this forum. I have a ethicon -300 scalpel and when i try to use gives me the foot switch fault #6. alreday check the cable and foot switch and are OK. when i try to work with hand activation, the generator gives me the error #7 hand switch, already replace cable and instrument/ hand switch and still gave the error code. if you guys can help me will be great. Thanks for you time.Reply |
[list] [*] Indicated for soft tissue incisions when bleeding control and minimal thermal injury are desired [*] Utilizes energy to enable haemostatic cutting and/or coagulation of soft tissue [*] 5 power levels [/list]
| Height | 5.3 in |
| Length | 15.2 in |
| Weight | 7.48 kg |
| Width | 14.5 in |
