Luxtec - 9300
by Luxtec
Easy to use 300 watt Xenon lightsource
This easy to use 300 watt Xenon lightsource comes with 4 position turret , which has ACMI, Wolf and Storz connections standard plus one extra connection which can be Olympus, Pilling or Designs for Vision. Some units come with an optional automatic gain control (AGC) for endoscopic procedures. The light source can be mounted on an optional floor stand or wall mount. The lamp has an expected life cycle of 1000 hours with a color temperature of 5600 to 6000 degrees Kelvin.
-Linda P.
4 years ago
Need the direction to install new fans in this unit.
Hi, I need to know the direction the fans face in the Luxtec model: 9300.  I removed them and by the time the parts got here, I forgot the direction to install them. Thanks
-bgodfrey
6 years ago
Not working
Light source stopped working while in operation mode. When turn on and plugged up it does not make a sound. No motor, fan or any noise what so ever. What is wrong? Is it the light cord or motor?Reply
Bulb Life1000 hr
Height5.5 in
Length 16 in
Weight17 lbs
Color Temperature5600 to 6000
Width15 in
