Pulse Oximeter
Expect outstanding monitoring performance from the OxiMax® N-600™ Pulse Oximeter -- the flagship monitor in Nellcor's revolutionary OxiMax pulse oximetry system. The OxiMax N-600 Pulse Oximeter delivers accurate, reliable readings and works with the complete family of OxiMax sensors, so you can more effectively monitor a wider range of patients. The full-featured OxiMax N-600 Pulse Oximeter also includes Nellcor's unique SatSeconds™ alarm management technology, which offers a safe, practical way to reduce nuisance alarms.
- Simple, intuitive operation and easy-to-see display with dimmer and contrast adjustment
- Three display options: plethysmographic waveform, large numerics, and customizable real-time trend
- On-screen quick guide provides instant help to assist caregivers with monitor operation
- Convenient selection of adult or neonate alarm, and user-configurable power-on settings
- Fast-averaging mode (2 to 3 seconds) to more precisely track rapidly changing saturations
- On-screen viewing of 24 to 48 hours of SpO2 and pulse rate trends taken at 2-4 second intervals; printing capability
- Variable pitch beep tone enables clinicians to hear changes in SpO2
- Backup speaker with escalating alarm tones
- Interfaces with certain multi-parameter monitors enabling real-time patient information and true physiologic waveforms to be displayed
- Works with the Oxinet III remote respiratory monitoring system
- 7-hour battery life with battery gauge for convenient portability
| Height | 3.3 in |
| Length | 6.8 in |
| Weight | 5.8 lbs |
| Width | 10.4 in |
- Size: 104mm H x 302mm W x 257mm D (4.1” x 11.9” x 10.1”)
- Weight: 13 lbs (6kg)
- Front panel: on/standby; freeze; menu; pulse tone volume, up and down; alarm off; alarm off indicator; battery charging indicator; function keys (4), software configured. Rear panel: mains AC power ON/OFF control.
- Sealed lead acid. Operating time (fully charged): 90 min. nominal, 180 min.without graphics. Recharge period: 12 hrs typical. Charger type: internal, current limited, constant voltage.Battery fuse: 1XT 2.5 A, 250V, 3 AG.
