Olympus - CV-190
Easy access to the range of advanced diagnostic features incorporated into EVIS EXERA III endoscopes.The EVIS EXERA III Video System Center CV-190 offers simple access to a whole range of advanced diagnostic features incorporated into EVIS EXERA III endoscopes. A range of improvements assist in obtaining endoscopic images with maximum diagnostic yield whilst advanced Picture-in-Picture functions improve ergonomics in the endoscopy room.
FORUMSView All (13)
0Replies10 days ago | E400 error code on screen We use an MDR video touch 4k for capturing our images during endoscopic procedures, which sends them to patient electronic chart. We are getting an E400 code, but do not internally save images. Our scopes will not capture images since this error code came up. How do I fix this? If images are also being saved on the unit as a default, how do I delete them or change settings so we can capture again? Equipment: Olympus - CV-190 Reply |
0Replies3 months ago | Manage Images Cannot delete images Equipment: Olympus - CV-190 Reply |
0Replies3 months ago | Manage Images Option is greyed out Equipment: Olympus - CV-190 Reply |
[list] [*] Dual Focus - A unique OLYMPUS innovation based upon an innovative two-stage optical system enables the user to switch between two focus settings. With the simple push of a button, the desired observation mode can be selected: “near mode” featuring ground-breaking resolving power for close mucosal observation or “normal mode” for normal observation. Even in “normal mode”, EVIS EXERA III endoscopes feature an advanced level of resolving power compared to previous generations. [*] Brighter and higher contrast Narrow Band Imaging - NBI in EVIS EXERA III offers a significantly increased viewable distance compared to previous generations. The improved contrast combined with this increased brightness means that NBI opens new possibilities in assisting you in lesion detection and characterisation. [*] Pre-freeze - An exciting new feature, pre-freeze automatically selects the sharpest image when the image is frozen by the user. [*] Improved image processing - New and improved image processing delivers outstanding image quality thanks to reduced noise, reduced halation and improved colour contrast. The result: the optimum in image quality [*] Waterproof One-touch Connector - The new one-touch Connector enables a one-step connection to the light source and does not require a separate video cable for connection to the video processor. This saves time during procedure setup and dismantling. [*] Variety of signal output options - A whole range of signal output options are available dependent upon the monitor attached to the CV-190, enabling you to achieve the optimum image for the installed infrastructure. 16:9 and 16:10 format is available for HD monitors. [/list]
Height | 85 mm |
Length | 455 mm |
Weight | 10.7 kg |
Width | 370 mm |
