Olympus - CLV-190
by Olympus
Light Source
With the EVIS EXERA III Xenon Light Source CLV-190, pre-procedure setup has never been easier thanks to a new One-touch Connector for EVIS EXERA III endoscopes. The EVIS EXERA III Xenon Light Source CLV-190 boasts a range of new features designed to improve ergonomics within the endoscopy room. A new waterproof One-touch Connector enables fast and efficient setup without the need for additional cables. A new cooling fan design also helps to reduce background noise levels. Brighter, more powerful Narrow Band Imaging (NBI) delivers high contrast images of vessel structures, meaning the range of applications for NBI within EVIS EXERA III is increased. EVIS EXERA III Xenon Light Source
0Replies4 months ago | lampara xenon Reseteo de las horas, posterior al cambio de la lampara xenon Equipment: evis exera iii, olympus clv-190 Resetting the hours after changing the xenon lamp Equipment: evis exera iii, olympus clv-190Reply |
1Reply5 months ago | No light, NBI not light up. Please help. Thank you. No light, NBI not light up. Please help. Thank you. Equipment: Olympus CLV-190 Reply |
0Replies9 months ago | Machine Not working even after replacing with two different lamps Hi, I am a re-seller of the bulb The machine was not working even after we changed the original bulb that came with the machine (OLYMPUS MD-631) to a new bulb - the CERMAX PE300BFA. The client got back the lamp and said it is not working in the machine He requested to replace it to the CERMAX J2022 OR MAJ 1817 I did that as well He just bought back the second bulb (J2022) and claimed it is not working He is checking the machine through some type of continuity tester and claims that both bulbs were spoiled even though they were brand new. I am a 100% confident that the bulbs are okay but not sure what is going wrong with his machine. He connected a filament bulb and claimed that the Bulb is working when connected to the power supply of the machine. How do we trouble shoot Please help Reply |
Height | 150 mm |
Length | 476 mm |
Weight | 19 kg |
Width | 370 mm |
